DWG with multiparts being split by reader in FME
  • Oct 27, 2023 11:43 AM UTC
  • 176 views
Hi everyone,
I have a dwg with autocad blocks which has several layers of polygons, polylines and annotation. I have a workspace to extract and convert these to shapefiles.
The problem I have is that multipart polygons and polylines are being split by the FME reader. When opened with ArcMap or Autodesk TrueView, the multiparts appear correctly. I have tried to play around with the parameters of the dwg reader (entity option/advanced options...but everything I have tried so far has not worked and some of the settings read far fewer components than needed).
Anyone have any experience with this?
Thanks in advance! :)
Best answer by daveatsafe
Hi @kewhew​,
When the DWG reader explodes blocks, it outputs a separate feature for each component of the block, but maintains the relationship of the components using the format attribute autocad_block_number. You can expose this attribute on the source feature types, then use an Aggregator to group the components by autocad_block_number to create multiparts for each block instance.
FME 2023 introduced the option to read the blocks as geometry instances, which will automatically create a multipart from each block, and best reflects the actual structure of the block within AutoCAD. If you are using FME 2023, I would recommend enabling this option.
daveatsafe
Forum|alt.badge.img+24
  • Oct 27, 2023 9:26 PM UTC
Hi @kewhew​,
  • Oct 30, 2023 9:46 AM UTC
Hi @kewhew​,
Hi @daveatsafe​ thanks a lot for your response. I tested both options (just installed 2023 to try) and they work great! :)
