DWG to TAB
  • September 20, 2019
  • 24 views
bjudes
Forum|alt.badge.img+10
Hi
I would like to transform from DWG to TAB. My DWG's are currently in tile format, they each have a name eg. 1234.dwg and then within that they have multiple levels, so Road, building, Vegetation etc. Would it be possible to get this to directly translate into TAB. With a single tab file and then within the file I would have the multiple levels?
Thanks for any help.
B
Best answer by markatsafe
@bjudes Merging data is a very common workflow in FME. You can use Multiple File/Folder when selecting the DWG datasets. If you're relatively new to FME then these concepts are usually covered in the FME Introductory training that you local reseller will offer or is available on line
  • September 23, 2019
