DWG reader is slow...5 minutes to read small file
  • December 30, 2020
  • 35 views
townest
Forum|alt.badge.img+4
I have a DWG reader reading a single DWG with approximately 60 xrefs and small at 400 KB. It takes just over 5 minutes to read. I have turned off all unnecessary options including read xrefs, so it shouldn't be opening all 60 xrefs. Any tips on speeding this up? Thank you.
Tyler
FME(R) 2020.2.1.0 (20201130 - Build 20806 - WIN64)
danilo_fme
Forum|alt.badge.img+53
  • December 31, 2020
Hi @townest​
Did you try to read using the reader with transformer FeatureReader?
Thanks in Advance,
Danilo
