dwg read and print layouts to dwf/pdf
  • Aug 5, 2019 8:55 AM UTC
  • 7 replies
  • 118 views
sprongandre
I would like to read a dwg layout and print it to dwf.
Does somebody has an example how to fix that? :-)
Thanks!
pratap
Forum|alt.badge.img+12
  • Aug 6, 2019 9:27 AM UTC
Does "Autodesk AutoCAD DWF" writer did not worked?
sprongandre
It does, but only for modelspace, not for the layouts (paperspaces)
pratap
  • Aug 6, 2019 12:00 PM UTC
Are you able to read the contents from paper space?
sprongandre
Hi, yes I can read the content from the model and paperspaces. Also I can print to pdf, but I can't print a specific layout, I can only print the modelspace
pratap
  • Aug 6, 2019 12:47 PM UTC
When you can read then you can write as well...
Any how could you kindly send sample file to check
sprongandre
Hi Pratap,
See the attachments, hopefully you can do it! :-D
A0_A1 layout.dwgacad2dwf.fmw
chrisatsafe
Hi @sprongandre,
Did you have the Paper space selected in the reader parameters? If you only want to read the A1L layout, you will want to deselect the Read Model Space parameter in the DWG Reader parameters (also have Read model space entities through viewport deselected).
I have attached a sample workspace that writes to PDF - hope that helps: DWG_Layout_to_PDF.fmwt
