DWG labels to Feature class attribute
  • April 11, 2013
  • 62 views
Hi folks,
how do I populate a user attribute in a writer from  text label in reader?
The reader is a dwg file.
Thanks in advance
  • April 11, 2013
have you exposed the format attribute "igds_text_string" from the reader?
You might also need "igds_rotation" and "igds_justification" (see this article for more info), depending on your usage.
The format attributes "igds_insertion_x" and "igds_insertion_y" will always contain the lower left coordinate of the text label (use a 2DPointReplacer to convert them to a point geometry), whereas the feature geometry from the reader will contain the insertion point relative to the justification.
Hope this helps.
David
