DWG - Block to polyline
  • Jan 16, 2019 2:23 PM UTC
  • 499 views
mr_fme
Forum|alt.badge.img+9
I´m extrating data from Postgis to DWG. And I´m using template file, but my lines in DWG output are Block. I would like line as polyline. How I can solve this?
Thank´s
daveatsafe
Forum|alt.badge.img+24
  • Jan 17, 2019 12:30 AM UTC
Hi @mr_fme,
If you have User Attributes defined in your DWG feature types, and the writer Attribute Output is set to Inserts, FME will convert all the output features to blocks in order to store the attributes on them. You can change the Attribute Output to Extended Entity Data to prevent this.
FME will also write any aggregate features to DWG as blocks. Using a Deaggregator on the features before writing will prevent this.
mr_fme
  • Jan 17, 2019 12:37 AM UTC
Hi @mr_fme,
Hi @DaveAtSafe,
Work´s properly now. Thank´s
