duplicates + aggregator
  • July 5, 2017
  • 216 views
Hello,
I have four records with three attributes. Their values are:
GB172783.TXT PAG 8138
GB172783.TXT PAG 8135
GB467715.TXT SNC 4129
GB467715.TXT PAG 4131
I want to merge the first + second to:
GB172783.TXT PAG 8135, 8138
and the third+fourth to:
GB467715.TXT SNC, PAG 4129, 4131
I use the aggregator and merge (concatenate) the last attribute grouped by the first attribute. How I can set the second attribute? In the case of the 3rd + 4th I want to keep both (SNC, PAG), for the 1st + 2nd I only want to keep the value PAG once and not PAG, PAG. Thanks!
erik_jan
Forum|alt.badge.img+26
  • July 5, 2017
You can select both the second and third attributes for concatenation.
Then to remove duplicate use the AttributeSplitter, ListDuplicateRemover and ListConcatenator in sequence.
Not a really charming way, but it works.
erik_jan
  • July 5, 2017
I created a little example.
example.fmw
  • July 10, 2017
I recently discovered an interesting usage of XQeury expressions with a JSONTemplater and this might be a typical case where the usage can be applied effectively. I would like to share the potential with all of you.
See this workspace example: aggregate-records-with-json.fmwt (FME 2017.0)
JSONTemplater ROOT Template Expression: Aggregate the XML elements created by the SUB expression grouping by field1, and return a JSON object which contains desired values created with XQuery functions.
let $t := <t>{fme:process-features("SUB")}</t>return {    "field1": fme:get-attribute("field1"),    "field2": fn:string-join(fn:distinct-values({for $v in $t/s/@f2 return $v}), ","),    "field3": fn:string-join(fn:distinct-values({for $v in $t/s/@f3 return $v}), ",")}
JSONTemplater SUB Template Expression: Create an XML element containing the values of field2 and field3 as XML attributes for each record.
<s f2="{fme:get-attribute("field2")}" f3="{fme:get-attribute("field3")}" />
  • July 10, 2017
Another thought. Looks like simpler.
    "field2": fn:string-join(fn:distinct-values(fme:get-list-attribute("_list{}.field2")), ","),
    "field3": fn:string-join(fn:distinct-values(fme:get-list-attribute("_list{}.field3")), ",")
}<br>
