duplicate text lines
This is kind of a weird question I know BUT I will ask it anyway.
I have a very very large DXF text file and have some duplicate lines of text  that I need to erase.
Here is a piece of the file as an example
Text_Northing=13333
1000
Name=Eastern Isles
1000
1000
1000
1000
Feature_Serial_Number=10156
1000
1000
Date_Last_Amended=19930101
1000
What I would like to do is to remove the duplicate  lines with "1000" in them so that the file looks like this
Text_Northing=13333
1000
Name=Eastern Isles
1000
1000
1000
The question is can this be done in FME. I have looked at the StringSearcher but cannot seem to be able to select more than one line at a time usiong the regular expressions
Any assistance would be greatly appreciated.
The text file is too big to run through a normal text editor.
Thanks for any help
This procedure might help you.
(1) Read the source file line by line with a Text File reader. Expose a format attribute called "text_line_number", which stores the line number (1-based sequential number).
(2) Filter the text line features by the line number to separate the 1st line from others.
(3) Send the 1st line to a VariableSetter to assign the text to a variable (store the prior text for the next line).
(4) Send other lines to a VariableRetriever to fetch the variable value (prior line text); send the text line which is not equal to the prior text to the VariableSetter to update the variable (discard duplicate text).
(5) Write the text into a new file with a Text File writer.
Takashi
Alternatively, the AttributeCreator can be used to get the prior line text. You can then select the text that is not equal to the prior line with a Tester.
gio
Forum|alt.badge.img+15
  • May 6, 2015
Or read the text file with txt reader, stringsearcher to look for "1000" and a variablesetter on the found port.
Calculate differentce in linenumber (wich you must expose on the reader).
Any difference=1 you dithc, rest you pass.
Reassemlbe the rows and reorder (sort) the records by linenumber.
Yup, there are several ways.
The PythonCaller with this script may also be effective.
# Python Script Example
class FeatureProcessor(object):
    def __init__(self):
        self.prior = ''
    def input(self, feature):
        text = str(feature.getAttribute('text_line_data'))
        if text != self.prior:
            self.pyoutput(feature)
            self.prior = text
  • May 8, 2015
Just wanted to say thanks to you for the great assistance
