I have applied the Duplicator Remover to a simple excel file with one column of postcodes which have duplicated postcodes. I want to achieve an excel file of postcodes with no duplicates. However, when I inspect the 'unique values' output in the inspector, these value are in fact duplicated. Am I using this correctly or is there another tool I should use?
