Duplicate lines who contains a specific character
geo-x
Dear FME community.
I would like to duplicate lines who contains a specific character in a specific field and split the attribute of this field.
For example in this case I would like to duplicate and split the lines who contains the character * in the filed Field 3 and split it like that :
For begining I used a tester for make a filter on the Field 3 who contains the character *
Do you know how can I do that ?
Thank you.
Best answer by danilo_fme
Hi @lalandexavier
Please, see attachment the Workspace template:
Workspace template - Workspace_Duplicate.fmwt
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • November 13, 2018
Hi @lalandexavier
Thanks,
Danilo
mark2atsafe
Forum|alt.badge.img+49
  • November 13, 2018
As @danilo_fme shows, you don't need to use a Tester. The AttributeSplitter will do what you need. If there is no special character then the attribute remains unsplit. Then use the ListExploder to turn the list of values into separate records.
geo-x
  • November 14, 2018
danilo_fme wrote:
Hi @lalandexavier
Thanks,
Danilo
Thank you very much @danilo_fme that's perfect !
