Hello,
I have a simple workspace that is reading in a feature class from a source geodatabase and writing it out to my target geodatabase. I am using (and need to use) a drop and create table handling method to write the feature class.
The source feature class I am reading from is contained in a feature dataset. I don't want this feature dataset to be written out to the target geodatabase; I am only interested in writing the feature class it contains. However, the writer recreates the feature dataset from the source gdb, even though I left the Feature Dataset Table Creation Parameter in the writer null.
How do I configure my writer so that only the feature class from the source geodatabase is being dropped and created, while ignoring and not recreating the feature dataset?
Thank you.
