draw circle
  • Jul 2, 2018 1:29 PM UTC
  • 256 views
boubcher
Forum|alt.badge.img+11
How can I draw a circle with center coordinate (X,Y) and the radius value using FME
Forum|alt.badge.img+63
The 2DEllipseReplacer will do that for you. The Primary and Secondary axis values should be the same (i.e. your radius) to get a circle.
erik_jan
Forum|alt.badge.img+26
  • Jul 2, 2018 2:16 PM UTC
The easiest way is using the Bufferer transformer.
A round buffer around a point is a circle.
The radius will be your buffer amount.
boubcher
  • Jul 3, 2018 5:39 AM UTC
Thanks
Guys both works
