Drape several object using real coordinates
  • Oct 24, 2017 3:44 PM UTC
  • 69 views
Hi everybody,
I have a single orthophoto, and several 3D objects I created from a shapefile and the Extruder transformer. Both datasets share the same coordinates system (EPSG: 2154).
I am trying to texture all features using this same raster and the true coordinates which already indicates where each pixel should go. With no particular settings, each object is render with one entire copy of the raster, which is not what I want. But I can't find the way to set the texture coordinates properly.
Can you help me to find the right setting and/or the right transformers for my need?
For the moment, I use the ApparenceSetter transformer with these settings:
_xmin, _ymin, _xmax, _ymax being the bounds of each feature and XMIN, YMIN, XMAX, YMAX being the bound of the raster used for texturing. But this result with all featured rendered in black with stripes, so this setting is not right.
Thanks a lot for your help!
Jean
daveatsafe
Forum|alt.badge.img+24
  • Oct 24, 2017 7:55 PM UTC
Hi @jportemer,
In FME 2017.1, the AppearanceSetter has additional options for the Texture Mapping Type. The option Top Down Georeferenced would likely work best for you, since it uses the orthophoto georeferencing to properly apply it as a texture on your 3D objects.
  • Oct 25, 2017 7:31 AM UTC
Hi @jportemer,
OK I'll give it a try then!
Thanks
Jean
  • Oct 25, 2017 10:11 AM UTC
Thanks for the answer.
I upgraded my FME version and set on Top Down Georeferenced. But now I have lost the texture completely... I have checked; both projections are OK so I don't know what's wrong....
