Download INSPIRE RSS based on defined area
  • Jun 12, 2019 2:29 PM UTC
  • 66 views
hlynur
Forum|alt.badge.img+10
Hello.
I am trying to automatize, or at least making it simpler, to download multiple INSPIRE GML data from a RSS feed based on location of a defined area (polygon or coordinates) and preferably clipping the data to that same area. Then to top it all of to transform it to DWG/SHP.
Datasource is this:
http://geodata.nationaalgeoregister.nl/plu/atom/plu.xml
Anyone up to the task of assisting me or giving me tips on creating such an amazing workspace?
Best answer by itay
Hoi @hlynur,
You could download the gml (since opening it from the URL will result in downloading it anyway, so I rather do it myself so that I can make sure I delete the files after the proces) and then open it using a FeatureReader intersecting your area of interest.
Use a GeoRSS/RSS Feed Reader and it will provide you with the url's you need to get to the data.
Veel succes.
Itay
itay
Forum|alt.badge.img+19
  • Jun 12, 2019 7:47 PM UTC
Hoi @hlynur,
Veel succes.
Itay
