Doubts about Log in FME Desktop
  • Apr 3, 2018 1:54 PM UTC
  • 38 views
Hi everyone,
I would like to know because some logs in FME Desktop show me the message |Translation was SUCCESSFUL
But there are logs that show the results but not the message Translation was SUCCESSFUL:
2018-03-27 07:10:46|2344.9| 0.0|STATS |EstatisticaFluxo 11
2018-03-27 07:10:46|2344.9| 0.0|STATS |==============================================================================
2018-03-27 07:10:46|2344.9| 0.0|STATS |Total Features Written 11
Both Log are workspaces that run properly.
Thank´s
rylanatsafe
Forum|alt.badge.img+14
Hi @inovacaogis, I've seen this before – but only in the context of fme.exe crashing during the shutdown process.. Can you check the Windows Event Logs to see if there are any crash reports to correlate? After running the translation in FME Desktop – does the UI "hang" with the Stop icon activated and the Run icon still greyed out? Do you see fme.exe as a running process even after this translation "completes"?
Hi @RylanAtSafe I´m grateful for you response.
There are no Log errors related FME in Windows.
After the Workspace finished there are no fme.exe process in background... :(
rylanatsafe
Hmm, this is very strange to me! I'll see if any of my colleagues can chip in some thoughts... If this question remains unresolved for a period of time, please consider contacting Safe Support.
trentatsafe
Forum|alt.badge.img+7
Hi @inovacaogis,
Does the workspace make use of any Shutdown Python scripts? You mentioned you are seeing this behavior across a couple workspaces, are there any similarities between these workspaces(source/destination format, same dataset etc.)?
I agree with Rylan, this is quite odd with the fact the workspace/process does complete and end.
