Does the hidden attributes really have to pass through the pointonareaoverlayer?!
  • February 13, 2013
  • 6 replies
  • 25 views
hakans
Forum|alt.badge.img+8
Hi!
Yesterday, a college of mine and I, struggled with a funky workspace.
It is wery simple:
An area in TAB-format. A list of XY coordinates. A 2Dpointcreator and a pointonareaoverlayer. The points inside the area is written to a TAB-file destination.
Somehow, the points inherits the hidden attributes from the area(eg mapinfo_type=polygon) and will be considered to be corrupt geometry by the writer! The fme_type value of the features is naturally "point".
I didnt find it intuitive that is is...
What do you think?
Greetings from Go:teborg!
Håkan
fmelizard
Forum|alt.badge.img+21
  • February 13, 2013
If these attributes are not desired, you can remove them before writting (attributeremover or attributkeeper).
Hope this helps.
Forum|alt.badge.img+46
  • February 13, 2013
I have had similar problems with mapinfo attributes causing unexpected behaviour later in the workspace. The easiest solution is to remove these as a first step.
sigtill
Forum|alt.badge.img+25
  • February 13, 2013
If possible I prefer to use an AttributeKEEPER just before writing, instead of an AttributeRemover. This is to prevent any "junk" attributes to be written. Using Dynamic Reader and Dynamic Writer makes it more interesting...
hakans
  • February 13, 2013
Yes, you are all right here.
Yesterday we solved this problem the same way you suggest.
Does thoose junk attributes ever help?!
How about not bringing them on at all, unless you tell them to, by exposing them in the reader properties?
It all seems to be a work around for something that doesn't have to be a problem from the very beginning!
mark2atsafe
Forum|alt.badge.img+59
  • February 14, 2013
Hi Håkan,
I agree it's not ideal, but some users do actually want to merge format attributes (though not geometry usually). I'll file a request with our developers to see if there is anything they can do.
Incidentally, I usually use the AttributeExpressionRemover (now BulkAttributeRemover in FME2013) to remove anything starting (in this case) mapinfo_*
Regards
Mark
Mark Ireland
Product Evangelist, Safe Software Inc
sigtill
  • February 20, 2013
Hi Mark!
That reminds me about a setting we have on all our formats (Quadri, QMS, SOSI) in our own plugin (GDMMapper). On each writer we have the possibility to add a "Ignore attributes with names that start with:" So below all features with attributes that starts with "fme" and "autocad" will automatically be removed before writing to the SOSI-format. Might be possible to implement. Perhaps you can easily implement something like this on "all" formats?
Below is a copy of the settings for a writer:
