Does the 'dissolver' create multi-part geometries?
  • January 13, 2015
  • 606 views
Hi All,
Our 'all school boundaries' file can be dissolved into Elem, Mid, and High boundaries on the boundary number (elem_num) and/or boundary name (elem_name)
Using the ArcGIS Dissolver, I can dissolve with the 'create multi-part features' option, and I can accurately create the grade-level boundaries - even those with multiple parts that are then treated as one feature.
But with the FME dissolver, it actually breaks up features that were originally multi-part, and creates two features from them, and I can't create multi-part features.
I've tried dissolving by 1 field (elem_num), and 2 fields (elem_num, elem_name), and I get the same result - two features created from an original multi-part feature, and no multi-part features created.
I've also tried the aggregator, but I keep getting errors about intersecting edges, which I cannot find - but maybe that is the correct transformer to use?
Thank you!
Best answer by gio
The dissolver automaticaly deaggregates aggregates (multi-part-features). (the help states that) and dissolves only if there is some intersection betweenobjects. You can use group by to elem_num/elem_name
If you want to aggregate them, use aggregator (geometry assembly) and again same GroupBy attribute.
  • January 14, 2015
could you perhaps post some screen dumps that could help explain your question?
David
gio
Forum|alt.badge.img+15
  • January 14, 2015
  • January 14, 2015
Gio - thank you - I used an aggregator after the dissolver, using the same fields in both 'group by' parameters, and it works great!!! Thank you!
