Does resolving domain and subtypes not work when using the transformers Feature Reader and Feature Writer?
  • Oct 19, 2023 10:45 PM UTC
  • 278 views
steveflo
Forum|alt.badge.img+7
When I configure the parameters in FeatureReader to resolve domains and subtypes, it seems to have done it because when I connect it to an attribute manager I can see resolved fields. However, when I finish my process and connect them to a FeatureWriter the User Attributes tab doesn't show that it's going to assign domains to the fields that have been resolved.
I'm using FME Form 2023.1.0. I've had success dealing with domains using these two transformers before I upgraded to 2023.1.
Also not sure if it's relevant, but I'm working with an ArcSDE GeoDB.
evieatsafe
Forum|alt.badge.img+28
  • Oct 24, 2023 6:33 PM UTC
@steveflo​ thanks for your question! You may have to assign your attributes manually in the User Attributes tab of the FeatureWriter; however, if this worked in a previous version of FME like you expected then this might be a bug. I would suggest filing a support case with some sample data and your workspace for us to get an idea of how to reproduce this issue. Thanks!
steveflo
  • Oct 26, 2023 8:31 PM UTC
Thank you Evie. I'll make sure to do that.
