Hi all, I need clarification whether FME supports migration of Smallworld Electric Office data to ESRI Utility Network. Any lead in this aspect will be quite helpful. Please share if any portal is available as reference.
Page 1 / 1
@cschoudhuryit We have developed migration workspace template workspaces that can be used for a starting point. The templates illustrate migrations from esri Geodatabase Geometric Network to Esri Utility Network. By replacing the Esri Geodatabase reader with a Smallworld reader, you should be able to customize the workspace to undertake a Smallworld to Esri Utility Network migration. Resources available to you are:
- Smallworld configuration options - options for configuring a Smallworld reader/writer in FME
- Esri Utility Network Migration Tools - links to migration template workspaces, FME training on the migration tools, link to Esri resources for Utility Network Asset Package
