Does anyone have a better way of capturing the first 30 lines of the translation log?
  • Mar 13, 2023 8:36 PM UTC
  • 88 views
salvaleonrp
Forum|alt.badge.img+23
I need these translation log info to be part of my translation canvass so I can include them into the header of my report.
imageI used to have this solution in place but I'm hoping to find a more efficient way to include the info in my canvass and not the shutdown.
https://community.safe.com/s/question/0D54Q000080hedASAQ/using-the-processid-and-timestamp-as-my-log-name-failing-on-rename-with-py3x-but-not-27
Best answer by salvaleonrp
Hi @Renato Salvaleon​,
The LogMessageStreamer transformer won't return the first lines in the log file, so your best bet is to add a FeatureReader triggered by a feature close to the end of the workspace. Read the log file as a Text File.
You can get the location of the logfile by concatenating the FME_MF_DIR and FME_MF_NAME parameters, then replacing the '.fmw' at the end with '.log'.
I like that, no need for the shutdown script.
daveatsafe
Forum|alt.badge.img+24
  • Mar 13, 2023 10:35 PM UTC
salvaleonrp
  • Mar 13, 2023 10:41 PM UTC
salvaleonrp
  • Mar 13, 2023 10:49 PM UTC
Thanks @daveatsafe​, exactly what I needed.
Worked for me. I just have to expose the attribute text_line_data and do some string parsing and I get the results I need.
