Do we have a method instead of writing contains in parameters of Tester and how can insert excel file inside Parameter as Input
  • Feb 14, 2020 9:44 AM UTC
  • 6 replies
  • 67 views
soly
Forum|alt.badge.img+3
I am confused a little bit about Tester
So I have two questions about tester :
At first :i have attribute and I want to write for the same attribute around 15 field ,if contains then pass .
As example same attribute ,if contains v ,passed .
So I have to write 15 times for same attribute , and it is too much ,is there easy way to give tester once a time to pass .if conditions occur .
Second Question :
I have around 100 field ,in Attribute named building ,I want From tester to check if Name includes as example sam , then pass with another attributes but I does not want to change the name of building every time from the parameter inside tester , I have too many names for building and I want to do excel file out my workspace but as input file inside my code and I change everytime in excel file ,the name of building that I want to pass with another attributes then I got my result only include this building name and another Attributes.
Thanks in advance
  • Feb 14, 2020 1:33 PM UTC
For the first question, you could use a ListBuilder that combines the 15 attributes into a list and then a ListSearcher to find the value in any of the 15 listed attributes.
soly
  • Feb 14, 2020 2:36 PM UTC
Thanks for reply . i will try ur method if u can guide me also for the second question ,i will be thankful .
  • Feb 14, 2020 3:55 PM UTC
I'm afraid the second question needs a bit more clarification and some examples. :-)
soly
  • Feb 14, 2020 6:31 PM UTC
Could’ I ask ,if tester is the transformer that I should use in this case for the second question ,or Which transformer should I use?
@soly Does StringSearcher with a regex using OR (|) work for you?
soly
  • Feb 15, 2020 3:32 AM UTC
it works great.thanks alot
