Divide polygon into parts based on overlapping point attribute values
  • May 13, 2019
  • 71 views
Hi all
I have been tasked to try to autogenerate 4 districts based on the values of a number of points that fall within a polygon boundary.
Basically I have to split a polygon into 4 parts where the sum of a number value of the point dataset is a close to equal as possible.
I cant upload the real data as it is sensitive but I have created a polygon dataset and a point dataset
500 random points inside a box polygon. The points all have an attribute called "value" that is also a random number.
Does anyone have an idea for a workspace that can split the polygon in the box shape file into 4 coherent parts where the sum of the points falling withing the split polygons are approximately equal?
Best Regards Morten
Forum|alt.badge.img+38
  • May 13, 2019
I'd take a look at the point clusterer custom transformer to create groupings, then once your points are grouped create polygons around these points
