DistanceChopper transformer
  • Nov 27, 2018 8:50 PM UTC
  • 9 replies
  • 176 views
fer_ruiz
I used this transformer, and I need to create a value consecutive to could identify the parts consecutive, if you see the picture there ara a attribute "Loop to DistanceChopper_LOOP_Entrance1543350805 Input Splitter.BranchingFactory.Count (32 bit integer):" and each parts have a different vale and are consecutive but if i coul use this attribute.
i can´t used it, if i create a new attribue and use this value but no apear. What can i do to use this vale.
thank a lot whats happend with chat online??????? i see some days offline... :(
Hi @ftl,
You can use the AttributeExposer transformer to allow this attribute value to be used downstream in the workspace.
Live Chat should be available 9-12 and 1-4pm PST the majority of the time. Occasionally there are internal events that mean this time can get short but this happens very rarely.
fer_ruiz
  • Nov 27, 2018 11:59 PM UTC
Hi @ftl,
Thanks @hollyatsafe, but when i use AttributeExposer and copy paste the name who apear in the inspector at attributeExposer, the value, when execute the workflow, are missing. no apear value.
Hi @ftl,
When you copy the attribute name over do not include the test in the brackets after .Count. I've attached a .fmw that shows this working.
none2none.fmw
fer_ruiz
  • Nov 28, 2018 12:22 AM UTC
Hi @ftl,
none2none.fmw
Hi @hollyatsafe, in the example that you have sent me the same as me, the exposer attribute appears as missing in the attribute table
  • Nov 28, 2018 1:11 PM UTC
The attribute name "Loop to DistanceChopper_LOOP_..." has been generated at run-time and it could be different for each run. If you want to use the attribute value in the subsequent workflow, implicitly rename it with the BulkAttributeRenamer and expose the resulting attribute name ('_loop_count' in the example below).
  • Action: Regular Expression Replace
  • Mode: Rename
  • Text To Find (regular expression): Loop to DistanceChopper_LOOP_Entrance\\d+ Input.+
  • String: _loop_count
Just be aware you would have to modify the regular expression if you edited the Transformer Name of the DistanceChopper transformer, since the attribute name contains the transformer name as its part. Further, it may not be guaranteed the name will be the same in future versions of FME.
I would recommend you to consider another solution without using the "Loop to DistanceChopper..." attribute as much as possible.
gio
Forum|alt.badge.img+15
  • Nov 28, 2018 2:49 PM UTC
@ftl
That parameter resists being exposed indeed.
Either remove the attribute __parts from the attribute remover (let the attribute pass)
or
Add a topologybuilder after the DistanceChopper, all parts are now enumerated. No exposure required.
I use this to do that with some options...nputscreen
The customtransformer
Workbench, attr-creator for initialising some attributes.
gio
  • Nov 28, 2018 2:51 PM UTC
@ftl
I forgot the conditionals in the creator
Hi @ftl,
I was using 'Run with Feature Caching' during my testing so I didn't hit the issue of the attribute name changing each run - it looks like Takashi's suggestion using Regex would be better here.
rahulsharma
Forum|alt.badge.img+12
Hi @ftl,
For your workflow, I would recommend using CHOPPER transformer instead with combination of LENGTHCALCULATOR and Counter, you can easily achieve the neccessary result.
Also, use this workspace as starting point.
DistanceChopper_Test.fmw
