Distance down road
  • May 17, 2016
  • 164 views
Hi, I am trying to create a service area of 2km down a road network from a known starting point. Ie select any road/or part of road within 2km of my starting point (via the road (not an isochrone)). The equivalent of ArcGIS service area. I have read and downloaded the FME "Calculate Emergency Travel Times" example but am a bit lost. Im guessing i need to use the Network Cost Calculator... Any suggestions or ways forward would be appreciated. Thanks Goatboy.
  • May 18, 2016
Hi @goatboy, every day :) I think you are on the right track.
After calculating network cost with the NetworkCostCalculator (Output Optimal Cost As: Measure), extract measure values of the start and end nodes of each line. e.g. "m_start" and "m_end". You can then filter the lines like this.
  • [1] 2km <= min(m_start, m_end) --> the line is out of range --> discard
  • [2] 2km >= max(m_start, m_end) --> the line is within the range entirely.
  • [3] otherwise, the line should be snipped --> Snipper (Mode: Measure (Value))
See this screenshot.
  • May 18, 2016
Man your good! :-) . Yes that works perfectly. Your a star, and apparently never sleep!I had better start directing some of my salary into your bank account......
The TestFilter and Snipper are really doing all the work. I would have struggled to get those test conditions myself.
Thanks Again,
ps, I promise no more questions this week !!
Steve
fme4ever
  • April 12, 2017
Takashi, you are a genius, thanks for sharing your knowledge!!
nicholas
Forum|alt.badge.img+14
  • June 26, 2020
Hi @takashi just letting you know that this helped me out with my own question. I too wanted to generate streets radiating out from a point for a driven distance
