Dissolver error - INDEX FAILURE - requested predicate not implemented
oscard
Forum|alt.badge.img+21
Good morning.
I have a very simple workspace that reads some polygons from a SHAPE file, aggregates them depending on an attribute and dissolves them with a "Group By" using the same attribute.
This is working fine with FME Desktop 2017.1 (32-bits)
Today I wanted to update this workspace to FME Desktop 2018. I have tested it with FME Desktop 2018.0 (32-btis) and FME Desktop 2018.1 (32-bits). It always fails with this error:
"Dissolver(PolygonDissolveFactory_base_factory): INDEX FAILURE - requested predicate not implemented"
2018-10-17 11:47:04|   0.9|  0.0|STATS |Dissolver(PolygonDissolveFactory_base_factory): Dissolving 1523 input polygon(s) across 26 group(s)
2018-10-17 11:47:04|   0.9|  0.0|INFORM|Dissolver(PolygonDissolveFactory_base_factory): If the input dataset is large or complex, the dissolver could run for extended periods of time without logging
2018-10-17 11:47:04|   0.9|  0.0|STATS |Storing feature(s) to FME feature store file `C:\Users\OSCAR~1.DIA\AppData\Local\Temp\SHP_a_DGN_2018_114703\inspector.ffs'
2018-10-17 11:47:04|   1.3|  0.3|ERROR |Dissolver(PolygonDissolveFactory_base_factory): INDEX FAILURE - requested predicate not implemented
2018-10-17 11:47:04|   1.3|  0.0|STATS |Stored 253 feature(s) to FME feature store file `C:\Users\OSCAR~1.DIA\AppData\Local\Temp\SHP_a_DGN_2018_114703\inspector.ffs'
2018-10-17 11:47:04|   1.3|  0.0|INFORM|Saving spatial index into file 'C:\Users\OSCAR~1.DIA\AppData\Local\Temp\SHP_a_DGN_2018_114703\inspector.fsi'
2018-10-17 11:47:04|   1.3|  0.0|INFORM|Finished saving spatial index into file 'C:\Users\OSCAR~1.DIA\AppData\Local\Temp\SHP_a_DGN_2018_114703\inspector.fsi'
2018-10-17 11:47:04|   1.3|  0.0|ERROR |INDEX FAILURE - requested predicate not implemented
2018-10-17 11:47:04|   1.3|  0.0|INFORM|Translation FAILED with 2 error(s) and 0 warning(s) (0 feature(s) output)
I have two different shape files. With one of them, it only works with FME 2017.1. With the other one, the three versions work fine.
I do not undertsand what the error means, so I don't know which differences I should be looking for among the SHAPE files.
Does anyone have a clue about it?
Thanks for any help provided!
Best answer by fmelizard
Hi @oscard I haven't seen this error before. Please file a case via https://www.safe.com/support/report-a-problem/ Thanks!
fmelizard
Forum|alt.badge.img+19
  • October 17, 2018
gio
Forum|alt.badge.img+15
  • October 17, 2018
@oscard
..why would you aggregate them first and then dissolve on same group by key?
You even have the dissolver deaggregate them.
Is there a reason for the aggregation? Do you maybe concatenate or sum some attributes?
Seems like you can skip the aggregation(?)
oscard
  • October 17, 2018
gio wrote:
@oscard
The risks of copy/paste from a a much larger workspace without thinking!!
Yes, the Aggregator is kind of useless in this case. In any case, without it the error is still the same.
oscard
  • October 17, 2018
I will file a case. Thanks!
olivier
Forum|alt.badge.img+7
  • February 24, 2019
Hi @oscard,
I encounter the exact same error. Have you been able to identify the root cause and/or a workaround?
Thanks!
Olivier
oscard
  • February 25, 2019
olivier wrote:
Hi @oscard,
Thanks!
Olivier
I forgot about this!
My solution was using FME 2017.1
fmelizard
  • February 25, 2019
Hi @oscard and @olivier The Dissolver in FME 2019 betas is the fastest and most robust ever. If you can reproduce the problem with the latest beta - www.safe.com/beta then please file a case via https://www.safe.com/support/report-a-problem/
gio
  • February 25, 2019
olivier wrote:
Hi @oscard,
Thanks!
Olivier
@oscard
I have encountered this annoying problem a lot in the current 2018 version.
After removing all things unwanted, small parts, areas posing as lines etc.. I was still getting this error.
I found a object causing it. It was a donut with the hole object where this same hole contained a object which was identical to the hole-object but was not created as a hole-object. (...)
This object was created by a areonarea overlay to extract data for some expression.
Little piece of script now finds and removes or sidetracks them (if they occur) and the workbenches have not crashed on this issue since.
olivier
  • February 25, 2019
gio wrote:
@oscard
Thank you @gio! My process flow is quite complex and reads voluminous data. Indeed it involves Dissolver transformers after AreaOnArea operations. I have not yet been able to isolate the feature(s) responsible but there is a good chance that they involve polygons matching with donut holes. I suspect that the issue arises when the tolerance of the Dissolver is set on 'Automatic' instead of 'None'. The error did not occur at that specific Dissolver step during a rerun after changing the tolerance to 'None'. I will add more info in this thread when my test with the FME 2019 beta is done.
