Dissolve Polygons and generate list of those if the attribute value is different
  • Apr 15, 2019 9:33 AM UTC
  • 86 views
jugoslaviaa
Hi all,
I have overlapping polygons and I am using Dissolver to avoid this. However, I would like to keep some attribute from both polygons that are overlapping in case attribute value is different. For example, those polygons have attribute calls "Side" and i would like to have list of these in case of both polygon has different value for it such as Side = W and Side = E but if both attribute Side = W and Side = W.
I want to do it because in some cases i have 6 polygons are overlapping and if i generate a list regardless from the values of those attributes, I am having very long attribute list.
Thanks in advance.
Best
Best answer by ebygomm
Easier to generate the list then use a ListDuplicateRemover to keep only the distinct values.
Forum|alt.badge.img+54
  • Apr 15, 2019 9:35 AM UTC
jugoslaviaa
  • Apr 15, 2019 10:02 AM UTC
Thanks! It worked that why.
