Disappearing features written to MS/SQL
  • May 20, 2020 12:38 PM UTC
  • 70 views
lifalin2016
Forum|alt.badge.img+42
Hi.
I'm trying to write features to some MS/SQL tables, and my translation is apparently successful, and the log file shows lots of features written. No errors are reported.
However, the database tables in question are completely empty !
I have a few constraints on my tables, and some fields which may not be NULL, so that may be the cause, although I should have handled that. But where do I see what the actual problem is, since FME doesn't include any error message from the database in the log file at all.
Cheers.
itay
Forum|alt.badge.img+19
  • May 20, 2020 12:42 PM UTC
Could it be that your database connection is pointing to another database or schema?
lifalin2016
  • May 20, 2020 1:00 PM UTC
Ah, as is often the case, the error was another entirely.
I had problems with some ill-formatted GUIDs.
Now I'm stuck on some MS/SQL antics about foreign keys and unique indexes on nullable fields !
Closing the question.
lifalin2016
  • May 20, 2020 1:01 PM UTC
No, I triple checked that :-) I found a remedy, which (of course) lead to some other issues :-(
  • May 20, 2020 1:05 PM UTC
Generally speaking, if you think that important information about errors or warnings from the database is missing from the FME log, I would recommend that you flag this to Safe support. That way they can hopefully improve the logging in future versions.
