Different results for the same polygon overlap
  • Nov 14, 2022 9:26 AM UTC
  • 6 replies
  • 180 views
jorge_rosales
Forum|alt.badge.img+8
In this workspace, the results of AreaOnAreaOverlayer (using the default tolerance) and SpatialRelator (using a custom DE-9IM matrix) are different. I suspect it's a precision issue with the AreaOnAreaOverlayer transformer but it's curious that the transformer that doesn't allow changing the tolerance (SpatialRelator) is the one that works fine.
Best answer by markatsafe
@Jorge Rosales​ The primary difference between AreaOnAreaOverlayer and SpatialRelator is that AOnAO uses a tolerance for vertex comparisons and SpatialRelator does not. the calculated tolerance is usually very small and is reported in the log, in this case:
AreaOnAreaOverlayer (OverlayFactory): Overlaying with an automatic tolerance of 6.464405381000011e-9
but enough to match the vertices.
If you round the area coordinates (i.e. CoordinateRounder 5 decimals) then the results are similar.
danilo_fme
Forum|alt.badge.img+58
  • Nov 14, 2022 10:15 AM UTC
Hi @Jorge Rosales​
I downloaded your Workspace and checked the configurations.
In the FME Viewer the result is perfect for overlaps:
Exemplo
So, in transformer Tester - configuration:
Operator
Thanks in Advance,
Danilo
jorge_rosales
  • Nov 14, 2022 2:58 PM UTC
Hi @Jorge Rosales​
Exemplo
Operator
Thanks in Advance,
Danilo
Hi @danilo_fme​ if two polygons overlap then _overlaps is greater than one in the common part.
imageAccording to AreaOnAreaOverlayer the two polygons don't overlap, but according to SpatialFilter (which I think uses more significant decimal places internally) they do.
  • Nov 14, 2022 6:22 PM UTC
jorge_rosales
  • Nov 15, 2022 4:36 PM UTC
@Mark Stoakes​ , is what I suspected, but it would be more consistent if the results of both transformers were the same using the AOnAO smaller tolerance.
@Jorge Rosales​ It is confusing. There are good reasons that SpatialRelator and SpatialFilter cannot use a tolerance. One is that OGC specs do not support a tolerance. Consider a point that is in tolerance of a line, but not quite on the line. Is that now inside, outside or on the line depending on whether the predicate you select is intersects, touches, contains/within? It's pretty tricky...
AreaOnAreaOverlayer is a little simpler since it only handles areas
jorge_rosales
  • Nov 16, 2022 9:09 AM UTC
@Mark Stoakes​ Yes, I agree that it is not a good idea to include a tolerance parameter in the SpatialRelator and SpatialFilter transformers. In my case the problem was that I ruled out the existence of overlaps using the AOAO (automatic tolerance) and then using the SpatialFilter I got unexpected results because for the SpatialFilter there were overlaps. In any case, as you mentioned, one solution is to round the coordinates to a few decimal places at the beginning.
