Different results for StatisticsCalcutor - Cumulative and Complete/Summary.
  • Dec 14, 2017 4:20 PM UTC
  • 6 replies
  • 67 views
elzbieta
Forum|alt.badge.img+8
I will find how many different ID are for one GARDSNR and BRUKSNR.
I've correct answer with Cumulative (3), but in Complete and Summary Count is 5 (sholud be 3):
Parameters used for StatisticsCalculator:
Group by: GARDSNR BRUKSNR
Attribute to analyse: ID
Total Count attribute: Count
Thanks in advantage:)
fmelizard
Forum|alt.badge.img+22
  • Dec 14, 2017 7:52 PM UTC
Hi @elzbietalekve, can you please provide a screenshot of the data before the StatisticsCalculator?
  • Dec 15, 2017 2:01 AM UTC
Hi @elzbietalekve, we cannot say anything about if the result is correct, since your screenshot (pdf) shows only the first 3 records. Are you sure that the source table has just 3 records of (BRUKSNR=2, GARDSNR=14)? To determine if the result is correct or not, you will have to check all the records in the table.
  • Dec 15, 2017 2:09 AM UTC
The StatisticsCalculator with the same parameters setting as yours generates the following result from this table, and the result is correct.
BRUKSNR,GARDSNR,ID
2,14,169626054
2,14,169626336
2,14,169627390
3,15,169626336
2,14,169627390
3,15,169626336
2,14,169627390
elzbieta
  • Dec 18, 2017 3:12 PM UTC
When I use this sentence in SQLCreator:
SELECT MATRIKKELENHET.GARDSNR, MATRIKKELENHET.BRUKSNR, TEIG.ID, TEIG.NORD, TEIG.OST
FROM TEIG, MATRIKKELENHET, TEIGFORMATRIKKELENHET
WHERE TEIG.ID = TEIGFORMATRIKKELENHET.TEIGID
AND TEIGFORMATRIKKELENHET.MATRIKKELENHETID = MATRIKKELENHET.ID
and ((MATRIKKELENHET.GARDSNR = 16 and MATRIKKELENHET.BRUKSNR = 1245)
or (MATRIKKELENHET.GARDSNR = 14 and MATRIKKELENHET.BRUKSNR = 2));I get the correct answer in Complete, Cumulative and Summary.
And when I use another program I can see that is only 3 records for 2/14.
But when I use this sentence:
AND TEIGFORMATRIKKELENHET.MATRIKKELENHETID = MATRIKKELENHET.ID;
I get the strange Count = 5 in Complete and Summary.
elzbieta
  • Dec 18, 2017 3:19 PM UTC
I see that Pictures are not im mail: oadminelaantall-teigthis-is-from-the-sentence.pdf
elzbieta
  • Dec 19, 2017 11:51 AM UTC
I got all records from database and I've got just only 3 records for 14/2
