Difference between z attribut from two shape_polygon not exactly superimposed on each other
  • Jul 13, 2017 7:07 AM UTC
  • 8 replies
  • 94 views
Hello,
I would like to compare z attribut from two shape_polygon not exactly superimposed on each other (regarding XY). I don't have any common ID between polygons.
Here is an example. The red polygons have a z-value, and black ones another z-value.
Do you have any ideas ?
Thanks,
JoJu
pratap
Forum|alt.badge.img+12
  • Jul 13, 2017 7:13 AM UTC
When the data is not superimposed on each other and don't have unique number for identification then which points are you trying to compare?
can you post some more detail with screenshot to understand better
  • Jul 13, 2017 7:24 AM UTC
I have two datasets from different sources which are supposed to represent the same thing (but in reality, there are some little XY-differences). I try to quantify this differences.
I thought to compare the two shapefiles "cell by cell" (every 1m² for example). Then, I would be able to average the difference using the shape_polygon1 's outlines.
What I tried :
pratap
  • Jul 13, 2017 7:31 AM UTC
Sorry I did not understand your requirement.
you have source shp file as geometry (polygon) feature and you are using Image transformer and compare cell-by-cell???
  • Jul 13, 2017 7:48 AM UTC
That's it. It looks easier for me to obtain a raster with z-attribute from the shapefile so as to compare z on the basis of xy-position (since I can't pair polygons). But I'm certainly on the wrong track.
Thanks
  • Jul 13, 2017 8:04 AM UTC
Hi @joju, in your screenshot, I can see that there are black polygons and red polygons, and they are overlapping with 1 to 1 relations. In the situation, I think the SpatialFilter can be used to merge attributes of a red polygon to a spatially related black polygon. vice versa.
  • Jul 13, 2017 8:35 AM UTC
Thanks a lot, it works for the case you quote. Moreveover, SpatialFilter allows me to separate 1 to 1 relation from other cases (one of my goals !)
However, I've also the following thorny case : one red building contains many black ones. I'd like to compare red mean z-value from each black ones.
example_2
  • Jul 13, 2017 8:54 AM UTC
example_2
In the case (i.e. 1 to N relation), the SpatialFilter still can be used (Red polygons -> Filter, Black polygons -> Candidate) .
However, if there can be M to N relation, it could be necessary other approach depending on the requirement.
  • Jul 13, 2017 9:20 AM UTC
There aren't M to N relation.Thank you, it solves the issue !
