DI: How to make solids transparent for inspection ?
  • Jun 8, 2018 7:11 AM UTC
  • 128 views
mhab
Forum|alt.badge.img+10
Is there a way in FME DataInspector to make 3D solids "partly" transparent, like area filling is now ?
I have quite hard times to inspect the parts of a solid when I need to always rotate it so that the marked vertex/point is in foreground.
It would help greatly if it would be possible to see through the surfaces.
Michael
owen
  • Jun 8, 2018 7:24 AM UTC
Yes, try the GeometryColorSetter alpha value
mhab
  • Jun 8, 2018 7:29 AM UTC
OK
That would mean I need to decide about transparency before the DI is invoked.
If I read a CityGML file into DI I don't see when I should set any transparency ... ?
owen
  • Jun 8, 2018 11:20 AM UTC
OK
No, I dont think you can do that unless your format supports materials
mhab
  • Jun 8, 2018 12:05 PM UTC
I suggested an improvement for DI
see: di-transparent-rendering-option-for-3d-solids
