Detect line relationship line
  • Jan 9, 2019 8:08 AM UTC
  • 5 replies
  • 70 views
piotrek6116
Hello to all forum members,
I am looking for lines that have a close relationship between each other ~10 [cm].
The result is a blue line.
pictures: a), b), c) it's results from the workflow:
pictures: d), e) found a similar solution only the lines have a real relationship, they intersect.
Transformer: LineOnLineOverlayer and finall LengthCalculator so it's easy to detect.
I tested: NeighborFinder, LineDevider, Snipper, SpatialRelator
Thank you for your help.
Best answer by piotrek6116
Thanks for answer from members,
but the answers do not match my assumption.
I've built a new one workflow 'test' but no exactly what i want.
Input data
Results the workflow 'test' - it's the big red point, that is place when blue line should touch each other around 0.02 cm.
I am looking for a result only green line. Image edited in "paint".
I exclude the relationship on the dots from the example
Forum|alt.badge.img+63
If I understand you correctly you do want results a, b and c, but not d and e. A SpatialFilter can be used to detect the intersects.
Alternatively, since the AnchoredSnapper changes geometry, you might want to consider using the NeighborFinder instead.
  • Jan 9, 2019 9:37 AM UTC
I agree with @redgeographics, you could also consider using the regular Snapper set to end point snapping and a tolerance of 10cm.
Regarding the NeighborFinder, you may want to consider only using the start/end vertices, you can use the CoordinateExtractor/VertexCreator combination for this.
piotrek6116
  • Jan 25, 2019 1:39 PM UTC
Input data
Input data
Do give the NeighborFinder a try, from the _closest_candidate_x, _closest_candidate_y, _closest_base_x and _closest_base_y attributes that green line can be reconstructed.
piotrek6116
  • Jan 28, 2019 6:45 AM UTC
Yes that's works. Final results present VertexCreator, thanks for help.
