Detect and remove extra spaces with other characters
  • Dec 18, 2018 11:02 AM UTC
  • 364 views
I am attempting to remove extra spaces and other characters from a attribute entries. I was able to find small script that does the job but in python.
For Example:
point_NAME (Before Processing)
A B C Bank , DreamTown
point_NAME (After Processing)
ABC Bank, DreamTown
I am able to detect the points which have these extra spaces and I am attempting to pass these on to pythoncaller transformer.
I want to use this syntax in python caller. Can someone help me out?
import re
string4= "POI_Name"
print (re.sub(' +', ' ',string4))
Thanks for all the help in advance!! :)
@takashi @david_r @Mark2AtSafe @MarkAtSafe
Forum|alt.badge.img+54
  • Dec 18, 2018 11:39 AM UTC
A string replacer using regex is probably a more straightforward way to do the replacement. Although I don't think your regex does what you want it to.
((?<=[A-Z])\s(?=[A-Z]\b))|(\s(?=\,))
If you want to remove the spaces between the single letters but not the words you will need something like. This is removing spaces that are preceded by a single character and followed by a single character and which come before a comma. This works for your single example but depending on other values in your data, you may need something slightly different.
If you really wanted to use a pythoncaller (*note the slightly different regex)
import fme
import fmeobjects
import re
def processFeature(feature):
    string4 = feature.getAttribute('POINT_NAME')
    newpointname = (re.sub('((?<=[A-Z])\s(?=[A-Z]\\b))|(\s(?=\,))', '',string4))
    feature.setAttribute('NEW_POINT_NAME', newpointname)
  • Dec 19, 2018 3:40 AM UTC
import fme
import fmeobjects
import re
Thanks @egomm.. I will test this.
Considering different cases
they could be as below.
Test caseExpected outputtext Space Comma text commatext Space comma Spacetext comma spacetext Comma Space Commatext comma spacetext Double commatext commatext comma dot texttext comma texttext hypen commatext comma
Thanks again!
Cheers,
BokaJ
  • Dec 19, 2018 4:00 AM UTC
import fme
import fmeobjects
import re
Hi @egomm,
I tried the pythoncaller statements and it was giving me error
"Python Exception <TypeError>: expected string or buffer"
I edited the code to pass string instead of list object and now it works fine.
import fme
import fmeobjects
import re
    newpointname = ""
    for row in newpointname:
        for cell in row:
        feature.setAttribute('Corrected_POINT_NAME', newpointname)
Thanks again for the foundation!
Cheers,
BokaJ
