Detach and Attach SQL Express Database
  • Nov 21, 2017 9:50 PM UTC
  • 161 views
I am attempting to develop a workflow that detaches a SQL Express database, downloads and copy an updated version of the database, and reattaches the database. I have the middle section working (FTPCaller and filecopy writer), but I'm struggling with the attach and detach. I keep thinking there might be a way to do this using a startup and shutdown script, but I'm not having much luck. Has anyone had any success doing something similar? Any suggestions are greatly appreciated. Thanks!
Best answer by takashi
Hi @tara, according to relevant Microsoft documentations, both detaching and attaching can be performed with Transact-SQL statements. I therefore think you can detach and attach a database file from/to a SQL Server with the SQLExecutor transformer. e.g.
Detach the database file storing the data of "test" database.
EXEC sp_detach_db 'test', 'true';
Attach the "test" database file.
CREATE DATABASE test
    ON (FILENAME = 'C:\<data folder path>\test.mdf'),
    (FILENAME = 'C:\<data folder path>\test_log.ldf')
    FOR ATTACH;
In my quick test, the SQLExecutor with SQL statements above worked as expected. However, there seems to be some limitations and restrictions depending on the actual database side conditions. See here to learn more: Database Detach and Attach (SQL Server)
Hope this helps.
  • Nov 22, 2017 8:57 AM UTC
    FOR ATTACH;
Hope this helps.
  • Nov 22, 2017 4:44 PM UTC
    FOR ATTACH;
Hope this helps.
Thanks @takashi. I appreciate the response. I tried something similar, but I'm afraid I'm having issues creating a database connection to the SQL Express database (i.e. on the local machine). I use <servername>/SQLEXPRESS as the Server and <databasename> as the database, with Windows Authentication (as well as many other similar connection parameters), but I'm afraid it isn't working. Therefore, it won't work to use the SQLExecutor if I can't set up a database connection. Additionally, I'm worried that even if I do get the database connection to work, if I detach the database, the database connection will no longer work, so I will not be able to reattach. It looks like I need to be able to make a connection to the database engine, and not the individual database inside of the engine. Thank you for the suggestion though!
  • Nov 22, 2017 11:44 PM UTC
    FOR ATTACH;
Hope this helps.
Naturally you cannot connect a detached database any longer. Try using another existing database to connect the database server.
  • Nov 27, 2017 10:13 PM UTC
Thank you for the help @takashi! After I was able to figure out the database connection issues I was having with SQL Express (the SQL Server Browser service was stopped, duh!), this worked perfectly. As always, your feedback is much appreciated!
