delete data from cells
  • Jul 27, 2020 11:15 PM UTC
  • 66 views
I am using a KML file exported from a GPS device and using FME I have have translated the KML to excel. I want to use a transformer to remove the extra text in the cell that I don't need and retain the text that I do need to conduct a match to the image file. Example below shows the italic text is the text to be removed and the bold text is the text to be retained
Cell
<a href='images/insphere/14325921-964c-4024-b002-8cb1549f232d.jpg'><img src='images/insphere/14325921-964c-4024-b002-8cb1549f232d.jpg' width='250'/></a>
Image fiile
danilo_fme
Forum|alt.badge.img+58
  • Jul 28, 2020 12:11 AM UTC
Hi @theunderwood07
I suggest you this KML Balloon Contents.
There is a example to use a image into KML.
Thanks in Advance,
Danilo
Hi, that was usefull, but what I am really chasing @Danilo is in the translation from KML to csv how do I remove the reference data path. I have the image files in the same location as the KML & csv. I was hoping to find a way to tidy up the csv output feild to match the photo image name.
  • Jul 28, 2020 7:27 AM UTC
Hi, @theunderwood07, a possible way I can think of is to use the StringReplacer with Replace Regular Expression mode.
  • Mode: Replace Regular Expression
  • Text to Replace (regular expression): .+(?<=src=)'.+/(.+?)'.+
  • Replacement Text: \\1
