Defining dataframe at Python Caller
  • Jan 29, 2020 8:30 PM UTC
  • 133 views
Hi there,
I am defining a data frame at Python caller on __init__ function like below:
class FeatureProcessor(object):
def __init__(self):
df2 = pandas.DataFrame(columns= ['INCIDENT_DATE',INCIDENT_MINS','INCIDENT_VALUE'])
later in the program at input function I am storing feature attribute value in data frame something like that:
def input(self,feature):
self.pyoutput(feature)
df2['INCIDENT_DATE'] = feature.getAttribute('DATE')
df2['INCIDENT_MINS'] = feature.getAttribute('MINS')
df2['INCIDENT_VALUE'] = feature.getAttribute('VALUE_LOST')
However, when I ran the Python caller block, it throws an error message that df2 is not defined at the input block. Could anyone point out where am I making the mistake?
daveatsafe
Forum|alt.badge.img+24
  • Jan 29, 2020 11:13 PM UTC
Hi @muhammad_yasir,
Objects you want to use in multiple methods should be prefixed with 'self.'
ie.
self.df2 = pandas.DataFrame....
self.df2['INCIDENT_DATE'] =
jseigneuret
Hum.
you create a feature output with same value input.
  and df2 dataframe can't be set in the constructor __init__ .
Create a method class to populate data and manipulate it add set your self.df attribute
at the end call a method to generate all your features
def close(self):
    exposeDf(self.df)
in exposeDf method you need create 1 by 1 all element in your df to create all features
