Datetime: %s / Epoch Time / Unix Time
  • March 21, 2017
  • 207 views
fmelizard
Forum|alt.badge.img+18
If you use %s (closely related to the Unix epoch time) to parse or format your datetime data, do you have datetime values that are either unzoned, or zoned but NOT in UTC time?
    When formatting
    • Unzoned datetime: 2017-01-02T03:04:05 ? What should formatting with %s return?
    • Zoned, UTC datetime: 2017-01-02T03:04:05+00:00 ? Formatting with %s is unambiguous.
    • Zoned, non-UTC datetime: 2017-01-02T03:04:05-08:00 ? What should formatting with %s return?
    When parsing/interpreting
    • Epoch time: 0 ? Is this 1970-01-01T00:00:00 (unzoned) or 1970-01-01T00:00:00+00:00 (UTC)?
    • Epoch time: 0-01:00 ? Is this 1970-01-01T00:00:00-01:00 or 1970-01-01T01:00:00-01:00 or 1970-01-01T01:00:00+00:00 or…?
    We'd highly appreciate any comments and suggestions, and any sample data with its interpretation.
    • March 21, 2017
    In almost all cases, a datetime without timezone suffix is considered as a local time, but formatting unzoned datetime (e.g. '2017-01-02T03:04:05') with %s format returns the epoch time assuming the source datetime as a UTC time. As far as I know, this is the only exception and therefore it sometimes could cause confusion. e.g. DateFormatter behaves oddly with seconds
    In order to prevent such a confusion, I think it would be better to simplify and clarify the related specifications. e.g.
    1. An unzoned datetime (except the number of seconds formatted by %s) should always be considered as a local time which is determined depending on the system environment.
    2. The number of seconds formatted by %s indicates always the elapsed seconds from the epoch (1970-01-01 00:00:00 UTC), and it cannot have any timezone suffix.
    3. When the user needs to process a zoned datetime (including UTC), they must add an appropriate timezone suffix explicitly to the datetime representation.
    So, assuming the current timezone is UTC+09:00 - Tokyo, Japan,
    • '2017-01-02T03:04:05+00:00' should be converted to '1483326245' with %s format.
    • '2017-01-02T03:04:05' should always be considered as '2017-01-02T03:04:05+09:00' unless the system timezone changed, and both should be converted to '1483293845' (= 1483326245 sec. - 9 hr. x 3600 sec.) with %s format.
    • Epoch time '0' should be parsed to '1970-01-01T00:00:00+00:00' (having timezone suffix) by default, but it might be useful if the @DateTimeParse() function could have another option to parse epoch time (and any datetime representation having timezone suffix) to local time. i.e. epoch time: '0' -> '1970-01-01T09:00:00+09:00' optionally [Edited]
    • Epoch time '0-01:00' cannot be parsed anyway, and the parsing function should return <null>.
