DateFormatter
  • January 30, 2015
  • 8 replies
  • 129 views
I Used a DateFormatter  to export MS Access data in the source format (DD/MM/YYYY)
eg 02/12/2014
Entered (%d%m%Y)
            (%d%/%m%/Y)
Data Attributes: DateField
Date Format: (%d%m%Y)
Source Format: DD/MM/YYYY
The output is: 20140122000000.000 - The output should be 2/12/2014
Any suggestions??
Thanks,
Clive
  • January 30, 2015
Hi Clive,
Generally, FME readers translate a datetime value into a character string of "yyyymmddHHMMSS" or "yyyymmddHHMMSS.nnn" format automatically.
If you are using the Access reader, connect an Inspector transformer to the reader feature type and check the datetime format with the Data Inspector.
Takashi
gio
Forum|alt.badge.img+15
  • January 31, 2015
Dont use automatic detection. That automaticaly puts all the zeroes.
Your second line ?
(%d%/%m%/Y) => (%d/%m/%Y)
Hi Gio,
How do you disable the automatic detection??
Regards,
Clive Swan
I created a Transformer (ExtractDate).
Date is exported as a number:
ExtractDate
20140122000000.000
20140122000000.000
Cannot see where to disable the automatic detection??
Thanks,
Clive
  • February 2, 2015
"DD/MM/YY" is invalid as the Source Date Format. See the help on the DateFormatter, and specify the source format in correct syntax.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dateformatter.htm
Date Attributes: ExtractDate
Date Format:     (%d/%m/%Y)
Source Format: (%d/%m/%Y)
Still exporting Native Oracle format (ExtractDate: 20140122000000.000)
  • February 2, 2015
If the source date format is "yyyymmddHHMMSS.xxx", FME can detect datetime automatically. Set "Unknown - Automatic Detection" to the Source Date Format parameter (but if you are using FME 2014 or earlier, you have to remove decimal places ".xxx" beforehand).
gio
  • February 2, 2015
or be done with it and just use tcl clock functions ....and take control ;) (i think fme uses that anyway, but tcl functions have a lareger scope)
