Date Range Tester
  • July 15, 2016
  • 57 views
bubblebeb
I am looking to be able to select two dates in a user parameter and then search a date field to test for dates between the two dates set in the parameters. Is this possible? If so, how?
erik_jan
Forum|alt.badge.img+26
  • July 15, 2016
The only way I can think of at this moment is if you format all dates YYYYMMDD.
Then you can do a numeric test using the Tester and the Between operator.
I have added an idea about this some time ago.
Have a look at: Date calculator
