DataUpdater not updating Oracle non spatial table
  • Mar 3, 2023 1:22 PM UTC
  • 84 views
sunsilk11
Hi, has anyone had an issue with updating a non-spatial Oracle (19) table. The table has been registered in SDE, hence has OBJECTID also.
There is no failure, but the record is not updated. If I use an SDE writer with update operation, it works fine, but takes over an hour for 300K records. I am using FME Desktop 2022.1
Any ideas ?
Best answer by markatsafe
@sunsilk11​ if your tables are versioned then it's very unlikely updating ArcSDE tables through a native database format will work because or the ArcSDE version tables.
  • Mar 3, 2023 4:34 PM UTC
sunsilk11
  • Mar 3, 2023 5:10 PM UTC
@Mark Stoakes​  thanks for the response.
The sde table is not versioned. There is no archiving also.
Is there a way to debug this?
sunsilk11
  • Mar 3, 2023 5:36 PM UTC
I found it. User error. An issue with databaseUpdater configuration.
