DATA VALIDATION IN EXCEL WITH DYNAMIC SCHEMAS
  • May 23, 2020 4:14 PM UTC
  • 7 replies
  • 251 views
Good Morning,
I am rather new to FME (RATHER). I have schemas and data coming for the next months, almost every day, in excel. EVERY TIME SCHEMAS WILL BE DIFFERENT (INCLUDING THE NUMBER OF FIELDS). My goal is to open a CSV file, explode the attributes (I think is the way to call it) and go from there validating each one. I need to test the length, not nulls, ASCII content (0-9, A-Z, a-z).
For many I know is a walk in the park. For my is going ascending to the everest.
Thanks a lot i advance.
Best answer by takashi
Hi @dkus2001, thanks for sharing the sample dataset. This workflow tests all the column values and detect ones that don't match one or more of the three constraints - text length, nullable, and only ascii.
Hope this helps.
  • May 23, 2020 9:27 PM UTC
Will the schema definition as shown in your screenshot also be provided as an Excel sheet every time?
If you would post a sample dataset including the schema definition table, it could help us to understand you requirement correctly.
  • May 24, 2020 4:08 AM UTC
arckt_schema.xlsxYes Takashi, and Thank You so much for the help...!!!
In that example there are only three fields or column names but I will be having about 64 column names in some tables.
Thanks again.arckt_data.xlsx
  • May 24, 2020 12:24 PM UTC
Hope this helps.
  • May 24, 2020 3:54 PM UTC
Hope this helps.
Takashi, Good Morning. Thanks a lot for your posting. Thank you so so much for your time..!! Would it be possible to have the FME file to learn from it looking at the options ? For the purposes of learning as I am learning the basics.?
Thanks a lot again...!!!
  • May 24, 2020 11:02 PM UTC
Hope this helps.
This is a workspace example: data-validation-example.fmwt (FME 2020.0.2)
  • May 25, 2020 12:31 AM UTC
Takashi
Again. A Million Thanks..!!
STAY SAFE..!! You are a brilliant mind..!!
  • May 26, 2020 12:28 AM UTC
Once more thank you...!!! (Maybe it is Greek thing to be endless grateful :-)
I learned so much from your answer...
