Data load
  • Mar 10, 2022 2:05 PM UTC
  • 62 views
fmesafe.podpora
Forum|alt.badge.img+11
I have a dataset containing attributes, but I can't read the coordinate value anywhere? The coordinates in the FME data inspector are. How do I load them in the workspace? Thanks a lot This is a loading xml of the model aixm 5.1
  • Mar 10, 2022 2:21 PM UTC
Hi @fmesafe.podpora​ , I think the dataset has been read correctly. If you need to extract the coordinate values as attributes, consider using CoordinateExtractor transformer.
fmesafe.podpora
This is exactly what I needed, just be careful, it must be used in combination with attributeCreator, thank you very much!
danilo_fme
Forum|alt.badge.img+58
  • Mar 10, 2022 2:35 PM UTC
Nice @Takashi Iijima​
