Data filtering
  • Feb 8, 2023 12:09 PM UTC
  • 71 views
fmesafe.podpora
Forum|alt.badge.img+11
Hello. You don't know which transformer to use. I tried testfilter, but there you can't combine two lines and featuremerger, it's also not quite ideal. I need to filter data in a database with a condition:
- all data with the same uuid
- a point that has the same value of validfrom and validto
validto changes to a value of -1 second down
The result should be validfrom 20220908000000 and validto 20221005235959 in the first line
In the second line validfrom 20221006000000 and validto 99991231235959
Thank you very much.
hkingsbury
Forum|alt.badge.img+73
  • Feb 8, 2023 6:53 PM UTC
I think the key to solving your problem is to get the two features with the same uuid into one feature. A rough order of operations to do this is:
  1. for the first set of input features, prefix "validfrom" and "validto" with "a_"
  2. for the second set of input features, prefix "validfrom" and "validto" with "b_"
  3. using an aggregator, aggregate the two sets of feautres, grouping by the uuid and making sure you merge attributes from all features
  4. you can now use a tester to remove uuids that don't have two "parts" - set the tester to pass features that have both "a_validfrom" and "b_validfrom" values
  5. you can now do an subsequent tests against the "a_" and "b_" values
  6. assuming you want the original features, you can then take the features from the previous step, just keep the uuid and use these with a featuremerger (as the supplier) and pass the original input features into the requestor port, merging on the uuid
fmesafe.podpora
Hi, that could be the solution, thank you very much for the detailed description, I will try it tomorrow and let you know.
fmesafe.podpora
Sorry for the late reply, but I was trying to test your tutorial today. I've tried different aggregator settings but can't seem to come up with a solution. I must be doing something wrong somewhere. I am attaching the WS test. Thank you
