Customize the FME Server Web User Interface
  • Feb 18, 2019 12:29 PM UTC
  • 8 replies
  • 266 views
lau
Forum|alt.badge.img+3
Hello,
I have seen this post concerning the customization of the FME Server Web Interface:
https://knowledge.safe.com/content/idea/42274/customize-the-fme-server-web-user-interface.html
In 2018.1: is there a workaround for changing the color of the "FME Server menu"? Can we modify a css file? Or ??
Thank you
Best answer by laurdedry
Nice!!
Thank you @jlutherthomas!
For those who are interested:
1/ Open the file: <%FMEServerDir%>\\Utilities\\tomcat\\webapps\\fmeserver\\styles\\safe-software-app.<%yourFMERelease%>.min.css
2/ Search for ".sidebar{background-color:"
3/ Replace the color.
4/ Connect to the Web Interface and look at the result ! (Pay attention to your web browser cache)
Forum|alt.badge.img+63
For FME Server the files should be accessible so yes, you should be able to edit those. I would strongly recommend trying this in a test environment first, just in case.
Another thing to consider, which may be easier than completely overhauling the standard interface, is see if you can build your own and use the REST API. I guess it kinda depends on why you want to do this.
lau
  • Feb 18, 2019 2:04 PM UTC
Hi @redgeographics,
Thank you for your reply. I would like to change the color based on the environnement (test, prod).
I tried to modify some css files but nothing happened. So if someone knows which file has to be modified, it would be cool!
runneals
Forum|alt.badge.img+32
  • Feb 18, 2019 11:24 PM UTC
@lau looks like if you change the .sidebar background-color https://FMEURL.COM/fmeserver/sass/components/sidebar/_sidebar.scss It DOES look like they are variables... Forgot about light and dark modes :P
Hi @redgeographics,
Hi @lau
You'll need to find in dev tools exactly which bit you want to replace, but you could try editing the safe-software-app-<build#>min.css file. Unfortunately it's minified so it won't be the easiest task.
  • Feb 21, 2019 3:06 PM UTC
Nice!!
marnickcle
Forum|alt.badge.img+8
  • Jan 18, 2023 10:31 AM UTC
Hi @redgeographics,
Hi @jlutherthomas​
Is there an easy way to customize the FME Server User Interface in a Kubernetes deployment on a cloud service?
Hi @redgeographics,
@marnickcle​ Unfortunately not. This is more of a hack than something that's properly supported. If someone needed an easy way to differnetiate between dev/test/prod when they're logged in I would recommend using Broadcast Messages and say something like "This is the test server".
Use the Broadcast Messages page to post messages to your users. For example, a broadcast message is a good way to notify users about times when FME Server will be unavailable due to system maintenance. Messages appear in a banner at the top of the Home page.
runneals
  • Jan 20, 2023 5:17 PM UTC
Hi @redgeographics,
You can do this on a user level, but only for 2 environments... Just use light/dark mode.
