Customise map in HTML Report
  • Feb 2, 2023 2:46 PM UTC
  • 445 views
marta.podsiad
Forum|alt.badge.img+12
I am struggling to change the color of polygon, line and point as well as popup and labels on map included in HTML Report. It seems like an easy task but I am struggling to find a solution.
I assume my questions are:
  • How to change the colour of polygons, lines and points on the map base on the value of the attributes?
  • How to edit labels and popups so they have different values?
I have followed the instructions from Add Conditional Coloring to Map section of How to Customize HTML Reports (safe.com). Unfortunately, suggested method is not what I am looking for.
I have attached my workbench.
Thank you for all suggestions.
Forum|alt.badge.img+63
When it comes to map layout the HTMLReportGenerator is rather basic unfortunately. Features can only have one color and the label can only be filled from a single attribute. Fortunately that is relatively easy to change, you can simply use an AttributeCreator before the HTMLReportGenerator and have it create a new attribute, filled with whatever you like and then use that as the label attribute in the HTMLReportGenerator.
marta.podsiad
Hi, thank you for your message and suggestion.
I am sure there have to be a way of doing it using Python
warrendev
Forum|alt.badge.img+28
  • Feb 3, 2023 7:51 PM UTC
The way I've done it might not be the best method, but what I've done is create a separate template file that contains my JavaScript, CSS, and HTML for my custom map and then replace and/or insert the data from the HTMLReportGenerator into the attribute value containing the html_content with python before it gets written.
marta.podsiad
Hi warrengis,
​I think that is the way to go. Could you please share the code? I am a beginner and do not know coding yet.
Thank you in advance
