Customer transformer converting string to integer
  • Jun 7, 2024 2:08 AM UTC
  • 213 views
jackyd
Forum|alt.badge.img+16
I am using customer transformers in a work space, but they are converting a string value to integer
The values are 002 and 003, they need to stay this way for the http calls inside the custom transformer but are getting converted to 2 and 3 (without the 00)
As read from db
After entry into the custom transformer
Any thought on how to prevent this?
I would like to have to avoid having do something in each custom transformer to revert the values back to the strings
Best answer by david_r
You can use a StringFormatter inside your custom transformer if you need leading zeros, e.g. using “03s” as the format string. If you think it’s a bug, I’d recommend you create a small sample workspace to reproduce the issue and submit it at support.safe.com.
  • Jun 7, 2024 6:27 AM UTC
jackyd
  • Jun 11, 2024 1:34 AM UTC
Thanks @david_r, I found the StringPadder which does the job easily and I will pop in a bug report, as it looks like unintended behaviour
