Custom transformer with group by attribute, not grouping
  • December 12, 2022
  • 0 replies
  • 69 views
tva
Forum|alt.badge.img+13
I'm having a customer transformer with a group by linked on an attribute:
Custom transformer parametersEvery feature that enters the Custom transformer (it has 3 input ports) has a value for that attribute.
I'm under the assumption that the custom transformer operates as follows:
reads all features, process features with value A first, next switches to value B and as last value C.
However in my workspace, the custom transformer processes all features in 1 go, regardless of the group settings:
image(I've added a logger in the beginning to indicate on which group it's working and it's logging all 3 a few seconds apart, while the CT needs to work a few minutes on group 1 and again a few minutes on group 2 etc).
Am I under the wrong assumption on how the group by should work for the custom transformer? Or am I overlooking something?
Also noticed that I can't assign a attribute anymore to the group by parameter:
