Custom transformer error in linked mode
  • Nov 10, 2023 1:37 PM UTC
  • 68 views
rzrnc
Forum|alt.badge.img+5
Hi;
I created a very simplified version of my custom transformer.
All it does is find the center point and define the layer name for the future dwg writer.
Attached is a custom transformer and workbench example, where dwg writer creates a dwg file with point in the default layer that come from custom transformer.
When I use the transformer in "linked" mode and start the entire workbench, I get an error.
When I use it in "linked" mode but with the use of feature caching to the transformer, and then I only start the dwg writer with "run to this", then it's ok.
When I use the transformer in "embedded" mode, everything works fine.
The difference in the translation log is in line:
"Using MultiWriter with keyword `PRIMARY_DEST' to output data (ID_ATTRIBUTE is `multi_writer_id')"
in embedded mode and
"Using MultiWriter with keyword `REDIRECTED_DEST' to output data (ID_ATTRIBUTE is `multi_writer_id')" in linked mode.
Note that the transformer was working properly before the upgrade to the new version.
Thanks...
Best answer by kailinatsafe
Hello @rzrnc​, thanks for posting! Sorry no one has reached out in a while, were you able to resolve the issue? If not, I think there was a bug in FME 2023.1 where custom transformers were failing to write in linked mode, the error on the issue is very similar to the one you've shared here. I suspect you've hit FMEFORM-29572, which has been resolved in the latest available builds. Can you upgrade and let me know if this resolves the issue? You will need to re-export the custom transformer for the fix to work! Happy to help, Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Nov 20, 2023 8:48 PM UTC
rzrnc
  • Nov 21, 2023 2:41 PM UTC
Hi;
Thanks for the information, everything is fine now.
