Custom coordinate system: "invalid number of parameters"
  • Oct 18, 2018 10:58 PM UTC
  • 72 views
I created a custom coordinate file using the online tool, but trying to restart FME results in the error message:
Coordinate system definition
'COORDINATE_SYSTEM_DEF Suddenlink DESC_NM "New Wave" DT_NAME NAD83 GROUP Cable One ORG_LAT 37.5 ORG_LNG -96 PARM1 45.5 PARM2 29.5 PROJ AE QUAD 1 SOURCE "New Wave" UNIT FOOT X_OFF 10000000 Y_OFF 5000000 MAP_SCL 1.0' has an invalid number of parameters -- no value is present for '1.0'
If I change the order of the values so that something else is on the last line, I get the same error with whatever is on the last line.
COORDINATE_SYSTEM_DEF Suddenlink \\
DESC_NM "New Wave" \\
DT_NAME NAD83 \\
GROUP Cable One \\
ORG_LAT 37.5 \\
ORG_LNG -96 \\
PARM1 45.5 \\
PARM2 29.5 \\
PROJ AE \\
QUAD 1 \\
SOURCE "New Wave" \\
UNIT FOOT \\
X_OFF 10000000 \\
Y_OFF 5000000 \\
MAP_SCL 1.0
Best answer by laurawatsafe
Hi @michaelschnack1,
Could you try putting the value for GROUP in double quotes? My first suspicion is that the space in the group name is causing trouble.
So, this line: GROUP Cable One \\ should be: GROUP "Cable One" \\
laurawatsafe
Forum|alt.badge.img+14
  • Oct 19, 2018 12:22 AM UTC
That's a winner. Thank you Laura!
