CSV reader fail to read negative integer as int. Issues with encoding
  • Oct 31, 2023 9:59 AM UTC
  • 221 views
so_much_more
I struggle to make FME read csv files with correct encoding and datatype.
I receive csv files in UTF-8 that includes non ASCII characters.
FME think its win-1252 encoding and this interpret signed integer values like -27 as −27 and thus make it a character datatype.
To fix the encoding i have to add the csv reader to the workbench and then change en Character encoding to UTF-8, then it works. But at that time the datatype is already set and I cannot change the varchar type column to be int32. It cause issues becasue now I cannot write to my database which expect int and not varchar...
So how can I change the datatype of multiple fields after the reader has been added to the workbench? Alternatively (and better), define the CSV reader to be using UTF-8 before the CSV file has been scanned for its content
geomancer
Forum|alt.badge.img+71
  • Oct 31, 2023 10:45 AM UTC
Workaround: in the Text File Reader you can set the Chararter Encoding (as part of the Parameters).
So a possible solution is to read the CSV as a Text File, and split the attributes afterwards.
  • Oct 31, 2023 1:05 PM UTC
You can go into Tools / FME Options and activate this setting, which will allow you to modify the reader data types:
imageThis way it should be possible to change from string to int32 in your CSV reader definition.
so_much_more
  • Oct 31, 2023 2:08 PM UTC
Thank you! That was an option well worth knowing. That solves the issues, thanks 👍
